Caledonian Tiling
Hi All,
Here are a couple of pics from my 1st customers job ever, as you will
see from my new member post, the walls around the workboard were
sh*t excuse the language, with about 1 1/2 inch "craters" in certain areas
with plaster board running up to an old runner where a door in the wall used to be, then dipped straight down to the brick back up to the cement level covering the brick then the large gaping holes around the sockets....lucky me...
I worked my *** off and stressed loads to level out trying to use filler at 1st
before finally bonding out with plaster... i learned loads but my god it was a tough experiance...
Cheers.
Cheers.
