1st paying job!!
macten
Excited and scared. Got my first job starting on Thursday - full bathroom refurb and all 4 walls + floor to be tiled.
Got to be done in 10 days!!!!
Customer seems quite laid back though - was asking him about grout joint size and colour, trim etc... He just said that I knew best.
His wife has demanded a bit of a feature to go in the middle of the bath wall.
Customer is supplying the tiles and it's going to look a bit like this, see attachment.
I intend to try and set out so the centre grout line of the paired patterned tiles is in the middle of the bath and see what kind of cuts it leaves. (think they'll except slithers as she is adamant she wants it central).
So wheres best to start tiling here? My thoughts were to fix the paired columns from bath top to ceiling and add the mosaic strips either side. Then work my way across and up either side of the mosaics.
Hope this makes sense and would appreciate your help on this one as I haven't got the luxury of time like I had previously.
Luxury of cash though:yes:
PS - walls aint too hot, gonna be back-buttering city!
Always start from your feature and work out from there especially if there is mosaics involved that way you simlpy glue up the wall and lay as you go. You'll want the walls as flat as possible when laying mosaics as buttering these is ny on impossible without making a mess. Also ckeck the thickness of the mosaics against the wall tiles, if they are only half the thickness then some backer board will need to be cut into strips and glued in before the mosaics, The mosaics should finish flush or slightly proud but never under.
Hope this helps.
Cheers Mick.
Good luck macten. remember to take plenty of progress pictures and show us all how it goes.
No probs Boosha.
Another quick question - How long are grouts + adhesives useable for after opening? Got a bit left over from last job so wondering if I can use that or should I bin it?
Cheers
I would guess you mean powdered adhesives and grouts.
For adhesive then as long as it has not started to go solid in lumps then it will be fine, as for the grout, and I presume your on about powdered too, well I wouldn't use it personally, just buy in some new so that way your going to get a constant colour.
good point on the grout Fekin - Thanks
Good luck macten,i'm sure it won't be as complicated as the other job you did which you posted on here the other week,but at least this time you will get paid mate,well done..
1st paying job!!
macten,
Ric,
macten,
Ric,
