Discuss 24000 laser in the Canada Tile Advice area at TilersForums.com.
so I end up scoring another 3-4 mm off and nipping away then it turns out a bad cut
well when i do my ceiling cuts i rest the tile up against the ceiling and then allow roughly 3-4mm. for each side of the tile. i then cut my tile in the centre of the felt line i draw. and then when i offer it up it is usually too tight so end up taking another 2-3mm off the tile and then it is too short. i am thinking it is just a matter of time before i start cutting in with that perfection that comes with the job
In that case if you cut down your line its your marking that is at fault. Try getting your eyes level with where you are marking. If your eyes are below the tile as you mark it you can make mistakes.
This is key! If you're not level with the mark, you're just guessing, and it's pot luck really... With experience, I think you learn to guess quite accurately, but for now, get up there!
Poor plastering, but quite common.. I never have a 3mm gap at the ceiling, I go for 1 to 2mm.
is it really poor plastering beanz? that is all ive ever come across so cant tell bad from good wish I had this experience!!!!!!!!!!!!!!
Reply to 24000 laser in the Canada Tile Advice area at TilersForums.com
