Discuss 24000 laser in the Canada Tile Advice area at TilersForums.com.
Colin!.. judging by your avatar.. would she allow you to fit one :lol:``
That's exactly how I measure my cuts, spacer size + 2mm. It works 99% of the time, occasionally an additional scribe is required if the ceiling has a bow, this only really occurs with large formats.
the first cut that doesn't fit is called a template
From what im reading here, your measuring the distance between the last tile and ceiling and taking 5mm off if the spacer is 3mm and you do this right around where the tiles meet the ceiling.
Do you also do this for floor tiles working to skirting boards
Any one know of where you can purchase a laser for a dewalt cutter every thing I have seen on line is expensive , the karl dahm one is over £100
Reply to 24000 laser in the Canada Tile Advice area at TilersForums.com
