240V LED indicator in fan circuit
  • Thread starter Thread starter Gabler
  • Start date Start date
I have installed an inline bathroom fan with timer plus lighting pull switch and isolator switch. I have also fitted a 240V LED indicator across the switched live and neutral circuit. This works fine except there is some feedback from the fans switched live circuit when the pull switch is in the off position (fan still running on timer) as the LED faintly glows. Any thoughts on how I can fix this or is it to be expected?
This LED indicator has been fitted in case I forget whether the pull switch is on or off (as the fan will continue to run either way).
Continue reading...
Electrical Advice
Tags Tags
None
Gabler,
Gabler,
