E
Discuss 365 drills in the UK Tiling Forum area at TilersForums.com.
Hi Kobbie, I made a guide out of some plasterboard for this size of drill. 365 recommend a bench drill for this size but making a guide out of plasterboard works really well.Hi, i purchased a set of these the other week for drilling porcelain tiles (also 12mm) and they drilled through like a hot knife through butter. This has been one of the best tool buys i have made, because in the past i have tried other drill bits/cutters with not alot of success. I have just purchased the 120mm cutter also, but not had a chance to use yet - but will let you know the result when i have done so. If you aint got a set of these in your kit then i would say it's a must get.
If the drill you use is a small one and the guide is worn, you can just drill another guide hole in the plate somewhere where there is a space big enough.I agree great kit but the guide can wear away pretty quickly.
Reply to 365 drills in the UK Tiling Forum area at TilersForums.com
