Discuss 365 drills in the British & UK Tiling Forum area at TilersForums.com.
E
enduro
Well what can i say about these drills, got to the job this morning and the foreman said the plumber cant drill those tiles 12mm porcelain tiles, i said i have a diamond drill that will do it no problem, thats what he had the foreman said....Panic set in then, anyway the plumber turned up and around 10am we were read to drill the holes, by this time we had quite a crowd of guys watching to see me fail, so i put my 8mm drill bit in my drill put the gauge on the wall and started to drill...AND GUESS WHAT IT DID IT, thanks 365Drills :thumbsup:
Deleted member 1779
Re: 365 drills : Diamond drilling of very hard porcelain tiles
Always good to know the drills perform as well as (or better than) expected.
Porcelain tiles are a tough nut to crack so we cant scrimp on the diamonds on the tip of each drill.
I've had the same scenario where a whole room full of people appear to see what these drill will do.
I went to a job where the tiniest bathroom was filled with sparkies, chippies, the designer, the tiler, the home owner, his wife and a couple of contractors waiting to see what would happen. Its a bit scary when they are all watching and waiting to see what happens.
Just as well they work eh !
The "Bathroom Fitters Kit-MAX" Seven careully selected drills in five sizes
E
eatsmice
After loads of reading on this site, I fell for the ruthless marketing! Thank goodness I did. Used the 16mm bit today and it left perfect holes for my heating piping.
First tiling job using large format tiles and was nervous of splitting them while drilling (before laying). Now have no fear at all and looking forward to doing the holes for the shower pipes.
Cheers.:grin:
E
eatsmice
Thought I'd add a bit of info.
These were Le Piezza "Porcellanato" tiles (500mm x 330mm x 9mm). Cut the tiles to 7cm width before drilling. Drilled flat on a workmate bench using a cordless driver at "screw" speed with constant flow from a hose. The cut took about 5mins at that speed, but the bit stayed pretty much cold throughout. I need to cut a total of 6 16mm holes in these tiles hence the slow speed, but I'll happily take advice if this is an unnecessarily slow speed?
Perfect cut to run Hep2o plastic radiator pipe through. Added a pic of the drilled tiles.
PS It was the Bathroom Fitters kit I bought.
Deleted member 1779
You are doing all the right things to get the maximum life out of the core and the most numbers of holes.
Providing you keep the core cold (max warm) you should
get the proper life span.
DONT : Heat the core. Drill too fast. Apply too much pressure.
DO: Keep the core cool. Drill at setting 1 on a hand drill. Apply gentle pressure.
If the tiles are not fixed and you can drill them outside its easier to apply a continuous water supply via a hosepipe - over a drain etc.
If the tiles are fixed (and vertical) Then holding a wet sponge under the core will cool it down plus it will collect the dust at the drill site.
Reply to 365 drills in the British & UK Tiling Forum area at TilersForums.com
Hello all, My name is Bill. I have registered on the Tilers Forum in order to try to locate...
I'm doing a cleanup / restoration of an old Art 4.A Sigma cutter and it's missing the top screw...
365 drills
Tags
usa
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
