Discuss 50m floor in the Canada Tile Advice area at TilersForums.com.
JMC tiling
558
hemel hempstead
My plumber just had a similar problem, his customer had seen a £100 tap and that's the one he was going to get, plumber quotes £45 for changing tap and customer accepts. Plumber turns up to do job and customer saw another tap that cost only £35 and now wants a reduction in fitting costs pro rata with cost of tap. One word, idiot!
£45 to change a tap is cheap as anyway ha ha! some people are unreal
peteablard
1,058
Cheshire
Why don't you read the posts and you would see the situation
I have read all the posts. At the end of the day if you don't value your own time then no one else will. If you do jobs cheap to start with then it's hard to ask for more at a later date, I understand that. It doesn't bother me if you do it for £50 a day, I was just giving my opinion like everyone else
Dumbo
I had a 350sqm floor on anhydrite.
I agonised over the price because the total looked so large but in the end went in at 25/m + materials and promised a perfect job.
Glad I did because it took longer than it should have done.
Issues around scheduling, other trades in the way, floor not as flat as should be...
I did ok in the end, but not as ok as it "should" have been....
Nothing is ever as it should be .
Dumbo
It's a funny one as I only do work for him on a slightly reduced day rate, often small jobs kitchens etc which I use to fill in gaps in the schedule so I can't suddenly ask for more on this one particular job!
If you work for him on a reduced day rate and you know you are not going to rip him off . Why do you need to know how fast . There is always somebody super quick who will reply to this . Not that this is super fast but once met a bloke who said any tiler should be able to do 15m a day like him . But after talking a little longer I figured he was doing 12 hour days.
Reply to 50m floor in the Canada Tile Advice area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
Wall & Floor Tiler Queensland Australia Tile Right About the role Seeking a Wall & Floor Tiler...
50m floor
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
