Discuss 70mm holes... in the Australia Tiling Forum area at TilersForums.com.
Never seen a core bit that fits on a grinder before, sounds a great tool, any chance of a link to that?
:drool5:Would scribing the hole and diving in the middle across at various points with an angle grinder n nippers work?
Sorry tea bag and anyone else that thinks this is the way to cut a 70mm hole, it most definitely is not... I did these holes this afternoon...I bought a 70mm diamond drill off the internet for less than £12.my advice would be to get some parrot pinchers drill a big enough hole and pinch away
But the problem is they really should be run at 30,000rpm (angle grinder speed) and these cores are set to be used with a drill which will only run about 10,000rpm so too slow for vaccum brazed.
Angle grinders run at circa 10,000 to 12,000 rpm. Rotozips and similar run as fast as 30,000 rpm.
We stock the M14 Vacuum Brazed Core bits, they are designed to be run at 10,000 to 12,000 rpm.
I also have the bosch grinder with the hole cutter attachments , thats a good piece of kit , do you do the core bits what attach to these grinders alan ???
Be nice to get paid by the hour and just drag the job on and on but I think the £10 a hole price is fair and the quicker you've drilled your hole the quicker you've earn't your tenner...3 holes=£30 in fifteen minutes, that's £120 an hour, think I might start a hole drilling service :smilewinkgrin:if I get paid per hour I can do holes using my finger.
when on price I got corer ready.
I reckon including marking up the centres of 3 tiles, walking to the van to get my water feed kit, drill and guide then drilling out the 3 holes in porcelain took me less than 15minutes...
Whats the point in drilling out say a 20mm hole then spending another 5 to 10mins nibbling away when a 70mm bit will do the hole in one go...when you times that by 3 you,ve just saved half an hour. Diamond bits of the correct size are the way to go for sure Cheaper than 3 chickens from Tesco:smilewinkgrin:
no word of a lie it would take m,e no more then 3 mins if that to get from a 20mm hole to a 70mm... just depends what pace you work at tbh. but yeh the best option is what you say mate and glad you found the answer you were looking for
No need to do it that way in this day and age , its like using a length of 2x1 to mix your addy or getting a horse to pull your car [emoji41]
I've got 362 horses that pull my car Craig
Seriously though, why on earth would you use old methods to do a job when the tools are available to do it more accurately and quicker :dizzy2:
All the crap in my van john i may need to borrow some
I also agree john, totally , i remember when i 1st got a electric tile cutter, around 1995 , i couldn't believe id used tile saws and nippers , i was like a teenager again who had had his 1st titty feel [emoji12]
Where did you plug it in cos there was no electric in Burnley in '95
Colne...your having a laugh Craig, they're still using candles n horses up there till this day.The site was in colne, its more or less ont yorkshire boarder, so we just had a extra long extention lead [emoji16]
Reply to 70mm holes... in the Australia Tiling Forum area at TilersForums.com
