Discuss A big flooring problem! in the UK Tiling Forum area at TilersForums.com.
H
hpandlou
Hello - apologies from a complete techno-phobe, so if this is in the wrong place, please advise! This is also my first visit and I am hoping someone may be able to give some much-needed advise!
As part of a kitchen extension (5mx4m), a new concrete floor slab was laid by a builder at the beginning of last year, with all requisite insulations etc. Piped water underfloor heating was installed to manufacturer's instructions and my plasterer/screeder recommended a floor screed with fibres to improve strength etc. This came pre-mixed in August and was duly laid to a depth of 65mm. Screed was left to dry and u/f heating was gradually turned on after approx 5 weeks - as we were recommended - to a max room temperature of 18 degrees. Tiler - highly recommended by a number of trades and shops as being 'the one you have to have' - came to lay the floor in mid-October. He was unhappy with the number of small hairline cracks in the surface of the screed and recommended we use 'Ditri matting' (spelling could be completely wrong!) so that tiles etc would not be affected by ant movement of the floor slab/screed. We followed advise and it was stuck down with appropriate adhesive and left 24hours to dry. Then he laid Brazilian slate tiles - 60x60x1cm - using a flexible adhesive and grout. Each tile was brushed/wiped on the reverse and seemed to be properly bedded down. Expansion gaps were left at all edged. U/F heating was not turned on until floor had been down for 4 weeks, and then turned on gradually again.
The floor appeared absolutely perfect and then, just after New Year, (so floor laid for 2.5 months approx), I noticed a slight noise when we stepped on just one tile and only when we stepped on a particular spot. I just assumed it was loose - no evidence of grout cracking or anything. Phoned tiler who was due to come back to attach slate skirting board, who was very surprised at the prospect of a loose tile but promised to look/sort etc. When he came one week later, 2 more tiles were noisy - a creak/snap/crunch/pop - but still no evidence of cracking. This week, half the floor is noisy, there is very small hairline cracks in the grout all over, and some tiles are very noisy. Most also sound hollow when tapped. The tiler thinks the screed has blown - I'm wondering if the adhesive has failed?
Any thoughts would be so welcome - apologies that I appear to have rambled!
Many thanks!
hpandlou
Alberta Stone
Sounds unusual given the ditra install.
Without detailed pictures it will be difficult to say more.
if a tile is loose then it would be prudent to pull it up and take some pictures close up of the back of the tile beside the spot it comes from.
But don't clean it before you snap the shot as that is part of what needs to be seen.
If the ditra mat is also loose then use a sharp knife to cut the square of matting out and take a shot of the condition of the screed surface as well.
Again, shots as you go with no clean up of the debris.
H
hpandlou
In all honesty, I don't know - I did see him spread adhesive on the ditra with a trowel, but didn't take that much notice. It wasn't a quick, rush job - the guy has been tiling for over 30 years, and it took 7 days to prepare and lay/grout/finish the floor! I will see if I can find out and let you know - thank you!
H
hpandlou
I don't honestly know because I was at work - I know we had to pay an extra £70 for specialist adhesive and it's a matting the tiler has worked with many times before. In fact, if we hadn't taken his advise and used it, I think we would have been asked to sign a disclaimer. It was left 24 hours for the adhesive to dry - don't know any more than that at this stage!
Gazzer
Ahhh now you see we would need to know what this special adhesive was as when I lay Ditra or similar I use single part flexible tile adhesive .
Reply to A big flooring problem! in the UK Tiling Forum area at TilersForums.com
Hi everyone I’m after a bit of advice. I’ve just removed the floor tiles in our on suite. After...
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
