hi Joun
regardless of grouting with epoxy and having a tanking system behind the tiles, if the dot and dab fixing method were to fail, who will you hold responsible for the failure. the professional members of this forum and Mapei technical have all emphasised that the fixing method used is completely wrong. The tiles need taking down and the room fitted from scratch to ensure it meets the required British
Standards.
Now if your contractor in charge of your refurb does a bunk because you've already paid him up front and he doesn't want the hassle, then you must learn from this situation that you shouldn't pay for work before it's actually done and completed to the satisfactory standard.
You cannot compromise on the safety of your children. You need to tell the contractor that the whole lot must be removed and started again, and it will not be at your cost, it will be at his. If the contractor chooses to seek losses from the tiler then that is for him to pursue separately. You are the customer and you are paying for the job. The job has not been done correctly. Your contractor overseeing these works needs to be held accountible for this.
GRR
