Discuss Adhesive for Black slate patio tiles in the DIY Tiling Forum area at TilersForums.com.
Perfect Tiling
I'd also recommend you use a pourable thickbed adhesive (PTB) seeing that you have tiles of varying thickness (uncallibrated). This will allow the tiles to be set level with varying depths of adhesive.....whichever make you can get your hands on at this time. I'd also use a primer of the same make..this will eliminate any dusty areas and also stop the sub base from drawing out the water from the adhesive too fast as it will be like a sponge being down for a year. If the base has any cracks you might want to put down a decoupling membrane as cracks in the concrete will eventually come through the tiles.
Reply to Adhesive for Black slate patio tiles in the DIY Tiling Forum area at TilersForums.com
Hi guys, had some great advice here before so thought I would ask here for advice again...
What is best way to lay outside 20mm Porcelain patio, Would I compact soil, add hardcore and...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
hailsham
What member type are you?
  1. DIY Wall and Floor Tiler
DIY Tiling Forum
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
