Discuss Adhesive spread direction in the Tile Adhesive and Grout Advice area at TilersForums.com.
Q
Qwerty
You say tomayta ... I say tomatoe...lol
If you back butter them ...They will bond irrespectively...
But if you trowel adhesive on the floor length ways when laying long planks you run the risk of trapping air in the ribs of adhesive, potentially leading to reduced bed coverage and voids. Yes they will bond, but maybe not as much as if you trowelled the adhesive the other way.
GAZ5518
558
EPSOM
Morning Plan Tec....
Excuse my naivety .. and I am always willing to take on advice... But .... Surely when a floor is serrated.. North to South.. East to West.....(Or the back of a Tile) ..Let's say with a 10mm square detail..The coverage will be 50%
When pushed/ Rubbed home .. The serrations collapse and theoretically should meet making a full bond..
I understand that when you say that serrations through the length of the tile may trap air ... But then surely that must be the case for every large format tile then, and I'm sure we don't lift every tile up to check otherwise..The next plank job I do , I will certainly put to the test though and come back with the evidence ... Be it damning or not..
Cheers:beercheers:
I
Italy
in my opinion,
now you are looking for the hairs in the egg.
we are talking about 120x20,
trapped air,
It remains a speech for large formats and that's it.
after all, I'm just an aprendist ....
and I NOT have no floor that is raised.
this is enough for me, I'm not interested in the direction of the adhesive.
(Again, I consider the answers above,
valid for large formats, example 100x50 and above)
GAZ5518
558
EPSOM
in my opinion,
trapped air,
;):eek::)
Q
Qwerty
I was referring to the question in hand here..... planks. The best way to trowel the adhesive in this situation is across the width, not length as I stated.
It stands to reason with large format, anything square or even rectangular that it is virtually irrelevant, but with a plank it is different. It is no extra effort to trowel the shorter distance and you are likely to have a better bed coverage. I only see the positives with this method I'm afraid.
Reply to Adhesive spread direction in the Tile Adhesive and Grout Advice area at TilersForums.com
  • Sticky
  • Poll
Which Tile Adhesive and grout brand did you use the most in the last 12 months? And also...
7K
Hi guys, had some great advice here before so thought I would ask here for advice again...
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
Tile Adhesive Trending Topics
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
