Discuss Advice for sub floor prep in the British & UK Tiling Forum area at TilersForums.com.
Hi,
Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl tiles stuck to screed. Should I remove vinyl and adhesive then prime and slc or slc over adhesive? There is a 5mm dip just in front of the front door so need to level that anyway.
The screed down now is 20 years old, no cracks, looks good, what is your advice on whether decoupling membrane is needed too?
Thanks in advance for any advice you offer 👍
Matt
Thanks for the advice Dave. I’ve removed the vinyl and scraped off the adhesive. Should I use slc even if the floor is already flat? I put a 1200mm level over it and there seems to be less than 1mm variance all over. The previous screed is 20 years old, good to tile on or is best practice to slc anyway.
Thanks,
Matt
Dave
Subscribed
389,936
1,000,000
Co.Durham
Thanks,
Matt
If it’s flat. You are good to go. 👍. Let us know how you get on.
Reply to Advice for sub floor prep in the British & UK Tiling Forum area at TilersForums.com
Hi everyone I am building my own house and now I'm ready to tile the floor downstairs. I have...
Moved this as I incorrectly posted in the Pro forum! Hi all, Finally getting to lay the tiles in...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Cheshire
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 2 1.2%
    Votes: 5 3.1%
