Advice for Wetroom Floor
Usually I find slate is very dirty so needs to be washed and completely dry before sealing, or take care with grout and adhesive seal when finished must be dry or picture framing !!
Thanks for the extra tips - now you mention it, the sales people did suggest sealing the slates both before and after laying, so I'll do that, and also wash & dry them first.
A couple of other questions while I've your attention too...
What's meant by the latex layer that goes on the UFH? Is this a powdered tile adhesive that's been enriched with a latex solution like this one, or something else?
Everbuild Floor Flex Plus Latex Leveller Liquid 5 Litre - https://www.goodwins.ie/products/everbuild-floor-flex-plus-latex-leveller-liquid-5-litre-0071025.html
Also, I've a couple of options regarding tile backing boards. There seem to be two types - cement boards like Hardibacker or this one here:
Permabase 8x4' 12mm Non Combustible Cement Board - https://www.goodwins.ie/products/permabase-8x4-12mm-non-combustible-cement-board-0023296.html
Or foam based ones like this one:
12mm Tile Backer Board 1.2 x 0.6mtr - https://www.goodwins.ie/products/12mm-tile-backer-board-1-2-x-0-6mtr-0023293.html
I'm guessing I'm better off with a cement board for a floor?
Sorry for all the questions!
Yes, it's a bit of an oxymoron sometimes!
A spiked roller helps a lot.
Foam core boards are fine on the floor providing you don't need the extra rigidity cement boards will give you.
OK, thanks - I'll get one of those.
Both types of board are more or less the same price here so I may as well go with the cement ones to be on the safe side.
Thanks again!
Not to confuse matters, but what about your backer board, then vario pro, or ditra heat, joints sealed, wires in then tile, that saves you levelling, saves time, less layers
Other brands are available, from uheat a forum sponsor too, they sell an elektra kit which is very good value
Deffinately seal slate before grouting. What sort of slate is it? Tell me it’s not riven !
Pointless using hardie & decoupling systems together
A 10mm backerboard will only decouple and won’t give any structural integrity to the floor. It’s simply an water resistent overlay to stop tiles debonding.
Both hardie, and ditra take out any minimal lateral movement. (Movement from left to right) not up and down.
Ditra Matt should allways be laid above the UFH
Easiest solution for wetrooms is a waterproof decoupling mat with tapped joints and paint the walls if desired (I allways do ) manufactures states only the floors need to be tanked.
So you’d only need to do the following
18mm ply wbp
UFH
Screed
Adhesive
Matting
Adhesive
Tiles
Deal
This solution will hardly raise your floor.
SimpleSimon,
SimpleSimon,
SimpleSimon,
SimpleSimon,
