Discuss Advice needed please- Substrate prep for floor tiling in the UK Tiling Forum area at TilersForums.com.
Plumbing Tiler
Hi All, hope you are well and keeping busy,
On Monday I am starting a full bathroom refurb with tiles on the walls and floor, the house is about 12 years old and in the upstairs bathroom I am doing several of the current floor tiles have come loose and most of the grout is cracked and missing, and there seems to be some movement when you 'bounce' on the floor.
With this in mind I have allowed for a worst case scenario approach, thinking that as I am taking the (presumed) chipboard T&G floor up to re-route pipework to new positions anyway I can install some extra 'noggins' between the joists to further strengthen the floor, then lay either new chipboard or 18mm wbp ply down, sealed with SBR, then overlay with 6mm Hardiebacker, layed onto SPF addy, and screwed every 150mm, with the joints taped with HB scrim tape and with say 2mm expansion gaps between the boards, then either tile direct onto this OR lay a de-coupling membrane onto the Hardiebacker to further minimise any risk of any future movement, what would you lot recommend please?, I am aware that the Hardiebacker will not provide any extra strength as such to the substrate so is there any extra benefit in using the 12mm instead of the 6mm if that is the case?, obviously I am very keen to take this opportunity to rip out the old and get it dead right to ensure the loose tile/grout scenario is not repeated!
The floor tiles are 600 x 300 x 10mm Porcelain.
Thanks in advance everyone.
martin1c
633
Cheshire
Sounds good to me. If you've added the noggins in and put 18mm ply, hardie (6mm should be fine on ply floor which is adequately strengthened) etc I don't know if I'd use the de-coupling membrane as it probably wouldn't be needed but some might argue that it's worth doing it for a belt and braces method.
Plumbing Tiler
What size is the floor? If its a small area and you get rid of the deflection, then leave the de-coupler out of the equation. As for the other prep, extra noggins, 18mm ply, then 6mm hardie glued and screwed, all spot on.
Sorry I forgot to mention the size, its a pretty small room really, only 1800 x 2600 mm, with a bath, vanity basin, bidet and wc going in it, cheers.
Reply to Advice needed please- Substrate prep for floor tiling in the UK Tiling Forum area at TilersForums.com
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
