Advice on how best to remove mastic bead from tile trim?
Could someone please advise the best way to remove a mastic bead from the top of a chrome coloured tile trim with minimal risk of causing scratches to the trim please?
Thanks in advance.
Only problem is,there will still be an almost invisible smearing of Silicon left on the tile trim
Wonderwipes or Isopropyl alcohol and elbow grease.
It will come off once you carefully remove the bulk mechanically.
Silicon eaters could damage anodised aluminium so be careful if you try that.
AOIS,
One Day,
AOIS,
One Day,
