chrisab
Hi all,
I want to re-do my bathroom which was a new build about 20 years ago. A bathroom fitter came around to quote and stated that because the walls are new build (stud wall) they will have a very thin plaster coating and what with water damage etc etc. it might be a big job. Is this really going to be a problem? I want to do this work myself, surely if the walls are that bad I can just put up some new board?
Are there any basic guides on doing a bathroom on this forum, i.e. include information of which backing to use, which sealants where etc? For example I've been reading about tanking, would the tiled area above a bath shower be required to all be sealed etc. OR do you just tile on top of water based plater board etc.?
Any advice much appreciated!
Also, if I were to tile the floor which is currently lino and 10mm below the caprpet outside presumably after boarding with ply, then I're read another board is needed, then the tiles - how to you then cover up a 10-15mm step into bathroom?
Many thanks
Many thanks
