Discuss Advice on Re-tiling New Build Walls in the UK Tiling Forum area at TilersForums.com.
if its that bad for plasterboard to get ruined,you would have to re do the job anyhow,and if the jobs done right,it should'nt failShelves and sills imo should be hardibacker. On a shelf there's a chance of water pooling as it can't run down the wall. Seal the grout and use the hardi to be absolutely certain your pantene has somewhere water tight and strong to sit. If any water gets through the tiles and grout on your shelf the plasterbaord is ruined.
if you have a look on here,at the side panel there are plenty of places you can buy tanking kits,i use tile giant,but its local to me and good lads work there who know there stuffthanks for the replies, much appreciated. I was going to tank all the shelf etc. as well. I've started ripping it apart and there's a metal strip on the edge of the step - i presume that is just to get a straight edge on the tiles?
Is there a cheap place on the interent to get tanking kits etc. from? I think there is a topps tiles, b&q, wickes around us buts thats about it.
Reply to Advice on Re-tiling New Build Walls in the UK Tiling Forum area at TilersForums.com
