Guest viewing is limited
Discuss Advice please on finishing Travertine Tile edges in the UK Tiling Forum area at TilersForums.com.
dmk
Hi
This is my first post so I hope people bear with me and that somebody can help on this. I have searched the site and have found some useful information, but I can’t find the exact information I need.
We are currently having 2 bathrooms redone by a local builder using 600 x 400 x 12mm filled and honed travertine tiles on the walls and floors. The builder’s tiler is planning to butt joint the tiles on an existing wall external corner, around the window reveal and also on the bath edge (we are having the bath inset into a large tiled box frame). He will then seal them, grout and then seal them again, but without finishing the edges any further.
My worry is that as some of these external angles will have both a mixture of factory machined edges and some a cut edges, by just butt jointing them, it will give an uneven finish and will spoil the overall effect of the travertine tiling. My wife is more worried that the edges could be sharp, especially the bath edge, with small children.
When I raised this issue with the builder the tiler has said that this is the normal method he uses and they will look fine after grouting, but after reading some of the topics on this site, my understanding is that these edges can be sanded or filed into a bullnose shape to give a better finish and effect. I have mentioned this to the tiler and he say’s he has never heard of this and that it can’t be done as the tiles are not solid, but honeycombed, so by doing this you would get voids and thus a poor finished edge.
Could somebody please give me some advise on this before I raise the issue again with the builder ?
Can and should these tiles edges can be sanded, and if they can, would somebody be kind enough to post some simple step by step instructions on how the tiler can do this and also how we can match the colour and texture of the sanded edge to that of the existing tile face, do we need to buy and use a colour impregnator ?
Many thanks
nybor62
1,083
rotherham
after what ive just read i would be reluctant to let that tiler any were near my bathroom but fixing is a no no.the edges of the tiles want bull nosing,and polishing.you also need to check for weight issues for the walls, what is the finish of the walls, there are some amazing natural stone tilers on here i think you would be well advised to use a tiler from here , just my opinion :thumbsup:
Yes they can be bullnosed, by hand or machine, any pockets ( honeycombs) you hit can be filled whilst grouting, sounds like he doesn't want the extra work involved, insist on it or tell the builder you want to find your own fixer, as mentioned above, plenty of great fixers on this forum. Where are you in the country ?
EDIT: here's a link to a few threads that go into bull nosing.
LINK
dmk
LINK
Hi Alan
Thanks for the quick response and links. As these tiles are a smooth honed finish, if the edges were bullnosed by hand using one of these rubbing blocks, what should be used after this to polishing / treat the edges to match the existing tile face finish ?
dmk
:hurray:Many thanks for all you help and links, it has really helped us with our problem.
I spoke to the builder yesterday and told him that he needs to ensure that all the external angle tiling is done using the eased corner joint (as kindly detailed by Wetdec).
It seems that his tiler has 'suddenly remembered' how to do this today !
So as one of you suggested, perhaps his tiler just didn't want to spend the extra time doing it !
Could we also ask one more question please, so we can check that it is all being done correctly ?
Can somebody perhaps just tell me how the tiler matches the finish on the eased corner joint to the existing tile face, is this done by polishing the tile edge in some way, or using a colour intensifier perhaps to restore it ?
Many Thanks !
Reply to Advice please on finishing Travertine Tile edges in the UK Tiling Forum area at TilersForums.com
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
