Advice Required - Material Spec
James M
I'm looking for advice on product regarding a bathroom installation.
I'm unsure at the moment whether the tile will be ceramic or porcelain.
I've currently got an 18mm moisture resistant chipboard screwed @ 150-300mm centres to joists and noggins.
I've been advised that laying a self levelling flexible screed, followed by 12mm hardibacker/cementitous board and screwed to floor while screed is still wet. Scrim tape joints in hardibacker @3mm and fill with flexible waterproof adhesive.
Could anyone advise if this is good advice as I seen to be getting mixed feedback from suppliers?
Would a self levelling waterproof screed be required above the hardibacker to act as the DPM?
Can anyone recommend product for this?
Cheers, Jim
Hardie fixed to spec then levelling compound. Not sure whay a dpm would be needed. If a wet room use a tanking compound or waterproof memrane
You could forget the levelling compound screw down the hardiebacker the tank all the joints with Ardex WPC ,had the Ardex rep in a couple of weeks ago and said they were compatible
Are you doing a wet room?
You should be fixing the Hardie on flexible adhesive and tape ing the joints using an alkali resistant Scrim tape and then trowelling over the scrim to a width of 150mm using the flat edge of the trowel . Oh and screw the boards as well .
Its not a wet room. Expecting typical water splashes from bath/shower screen etc.
When using adhesive what's the best product used to prep the chipboard. I've read on here that SBR/Febond etc is not advisable?
Is the hardibacker/tanking to the joints sufficient protection from water penetration.
Thanks for the advice.
I would fix the hardie on flex addy which should also help get level (Within reason ).
Scrim and trowel joints. Tank in wet room or better use non cement board. Tile with a flex addy
Are there any level issues?
sorry I would screw the backer broad to the floorboards then Ardex WPC on the internal corners & tape the joints also. is what you wanted me to explain,3 fall
No Andy, I was wondering why you would only tank joints and transitions with WPC?
As Harry said, (above) HB isn’t waterproof, surely it’d be a waste of your effort and money.
Also I believe hardie should be
Fitted like this
• Apply a supporting bed of mortar or modified thinset to subfloor using a 1/4” square-notched trowel.
• Embed HardieBacker cement board firmly and evenly in the wet mortar.
• Use the fastener pattern as a guide. Fasten HardieBacker cement board with specified nails or screws (as listed in “Materials Required”) every 8” over the entire surface. Keep fasteners between 3/8" and 3/4" from board edges and 2" from board corners.
Fitted like this
Who’s been read the American spec then? 😀😛
For the british
Apply a gap filling bed of tile adhesive to the subfloor using a 6mm notched trowel.
• Embed HardieBacker® boards with a sliding motion firmly and evenly in the wet tile adhesive.
• Stagger all HardieBacker board joints in a broken bond or brick pattern. Never allow all four corners of boards to meet at one point. Do not align with subfloor joints.
I personally don't agree that it's a waste of time & money? Okay, Hardiebacker not waterproof but its moisture resistant not like plasterboard which soaks up moisture like a sponge & after time so does the moisture resistant plasterboard. Also, I've stated on more than one occasion I trust Hardiebacker & this is a forum isn't it
Hardibacker soaks up water just like a sponge too.
Only it doesn't break down, but it WILL pass that water right through to the timber floor, studs, joist whatever.
Hardibacker is rubbish for wet areas and has no place in modern bathroom construction (in my opinion).
James M,
One Day,
James M,
One Day,
