Discuss advice with slate in the British & UK Tiling Forum area at TilersForums.com.
N
negsy26
hi all. i am new to this tiling business and have just got a job for some slate floor tiles and large format ceramic wall tiles with a slate border. any advice on the slate would be helpful as i have not worked with it before. is it ok to lay them on the floor boards , whats the best sealer, best way to grout and anything else that might be of use. many thanks all. nick.
F
frogeye
Hi Negsey
welcome to the site
New to tiling and taking on large format tiles and slate?
Braver man than me !
I am sure you are up for the task - but best of luck anyway
Grade the slate by thickness before fitting seems to be the way to go
but do a search on the site - the answers are there
off to bed - I have to clean up the minton tiles I took up in my own house in a rash moment and fix the mess I am left with - (at least no nasty dust)
frogeye
theyomper
As said above grade the slate into thicknesses. I normally do a small, medium.large. Start laying the thickest slate first as when you get to the thinner ones you can always build them up. Prior to grouting thoroughly clean the slate and seal with a colour intensifier. I normally do one coat before and 2 after. When grouting,and depending on the spacer used I will either use a grout gun or float, but just keep the area as clean as possible and dont do too large an area at one go. Regards the floor, there are many threads relating to floor prep in the forum. Any other ???? please ask.
wetdec
Colour ?
Size ?
Honed,Polished, Riven ?
Floor size ?
What type of floor boards ?
tiler
Let me try to explain something for you.
If you tell us the size of room we can help you with how best to prepare the floor, the tile size can have for eg a bearing on which way you might lay them.
If the finish of the tiles is given then it can help re, best sealer, best proces for fix, suitability to the job in hand.
The type of floor boards as there could be any number of differing types would help again in advising on preperation..
All of these things can help us help you in the long run and would get you more advice from people who know what they are about.
If asking for advice then condider these.:thumbsup:
tiler
Reply to advice with slate in the British & UK Tiling Forum area at TilersForums.com
I've had a look through threads but cannot find anything on this. Lots of info on commissioning...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
advice with slate
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
