Grout Advise Grout colour and type
I like the idea of Expoxy grout in a lighter colour to blend with the tiles, but what about the hardness of Epoxy grout and the tile expansion on to the 2mm grout from the underfloor heating ? Would this cause a cracking issue in grout or tiles ?
nobody answer?
simple, all allergy sufferers to use epoxy.
I just say, if it were my house, I would not doubt, epoxy.
itself breaks before, grouting cement-based or epoxy resin?
you do not need an answer, because who says resin breaks down, he does not want to epoxy.
nobody answer?
Thanks, would you have any concerns that the Underfloor Heating would cause the Porcelain tiles to crack because the Epoxy Grout is so hard, rather than relaying on standard flexible grout taking any compression ?
I'm really worried about cracking with UFH and hence layining the extra Durabase uncoupling layer.
Should have technically been a 3mm minimum joint.
I, personally, like a bit of contrast between tiles and grout and grout 3000, the ardex range Julian suggests and mapei ucp would all be fine
Grout
bwel,
ISOMAT UK,
bwel,
ISOMAT UK,
