All round manual cutter
If you want a rubi cutter then the ts50+ is a good all round dry cutter...the difference between the ts and tx ranges is......
1. TS has a fixed breaking mechanism..
2. TX has a movable breaking system..
Dave has the main difference there!
Also the ts range has a higher maximum cutting thickness, whereas the tx has a higher breaking power.
As Penno said in an ideal world you would have a few cutters for different situations and circumstances.
The most popular models we sell are the ts50+, ts60+ and tx700n. We have all of those in stock so 1-2 working days delivery.
http://www.buybrandtools.com/acatalog/Rubi-TS-Prof-Plus.html
http://www.buybrandtools.com/acatalog/Rubi-TXN-Prof.html
If youre interested pm me or call me on 01142513535 and i will try and sort you with the best deal possible.
Cheers Neil
i have the ts50+ and the tx700n .. a great combi for any situation......
I was thinking something along those lines, just cant afford 2 cutters right now so its just working out which one to go for first. Maybe a TS60 plus would be a compramise?
Also started looking at the Montolit Masterpiuma cutter now which is giving me more options, thanks grumpy.How Big is the Montolit Masterpiuma63 cutter(roughly) & does it come with a case? thanks :grin:
Check out a Montolit Masterpiuma 63. Big enough for most things, small enough to be portable. Dual breaking system.
Grumpy
Hey Grumps, I'm an advocate of the monty, same as yours, on a job today and the tiles are 635mmx300mm porcelain and guess what...the cutter won't do them...not big enough and there was me thinking it was a monster..:icon9:
5mm too long? What a swine
Grumpy
I'm with Grumpy ... but it really is down to trying the cutters for yourself! The Montolit Masterpuima with a mosaic mat will do everything you need. All your natural stone, porcelain and mosaics without any problems! I have seen other cutters and used Rubis too but nothing comes close to my Montolit!!
montolit
there is a montolit 14" cutter model 26a on ebay for £37.99, would this be considered a good price, and is it a good model.
Matthew77,
a1tiler,
Matthew77,
a1tiler,
