Guest viewing is limited
All Squared Tiling
All Squared Rob
At All Squared Tiling we offer a complete service to take as much stress and hassle out of "having the builders in" as possible. You just tell us what you want and we will deliver just that. We calculate and collect the materials required for your project prior to commencing work, we can even collect the tiles if required so all you have to do is sit back and watch your new tiles go up on the wall, or down on the floor for that matter!
As well as being able to install all varieties of tiles on walls, floors, wet-rooms, en-suites, kitchen splash-backs, conservatories, external paths/doorsteps or even swimming pools, we also provide the following services:
  • Tanking/Waterproofing - There are various products and systems that provide ways of protecting your property against potential future water damage to your property. They are used in and around shower/bath enclosures as well as wetrooms, and are applied prior to the area being tiled to provide a waterproof membrane between the tiles and the wall the tiles are being installed on.
  • Underfloor Heating - Our fitters are qualified to install underfloor heating if that is something you require. Underfloor heating offers low running costs, efficiency and environmental benefits, and being able to remove the radiator can greatly enhance the look of the room. It provides a more evenly spread heat throughout the room as you are not relying upon convection to carry the heat around as you do with standard radiators, not to mention those middle-of-the-night trips to the bathroom in winter become a lot more comfortable!
  • Tile Repairs - Loose, chipped or cracked tiles can ruin an otherwise perfectly good installation, not to mention leaving areas prone to water penetration and potential damage to your property. We can come and remove any damaged tiles and replace them, putting your mind at rest.
  • Re-Grouting - As grout perishes at a greater rate than the the actual tiles, it can relatively quickly become unsightly. Poor quality grout can also become mouldy as well as shrink and crack leaving gaps for water to get behind and cause more extensive damage. We can come and remove your old grout, and apply fresh new grout to your tile joints.
  • Silicon Sealing - As with grout, the Silicon seal around your bath, shower, basin, toilet or any other internal corner perishes more quickly than the tiles. Inferior Silicon can grow mouldy and come away from the corner leaving it vulnerable to water penetration and potential damage to your property. We can come and remove the old Silicon and mould and apply a professional quality new bead using industry leading, anti-fungal Silicon available in a variety of colours. You will be amazed at the difference this can make to a room, almost making it feel brand new again!
  • Tile Drilling - If you have a shelf, mirror, picture or anything else that requires drilling into tiles we can provide that service. Tile drilling requires specialist bits and if done incorrectly can lead to scratched, chipped or cracked tiles, so its best left to the pro's!
We serve areas in and around:
  • St Albans
  • Watford
  • Borehamwood
  • Radlett
  • Bushey
  • Barnet
  • London Colney
  • Potters Bar
  • Enfield
  • Hatfield
  • Welwyn Garden City
  • North London
Just contact us for a chat about your upcoming tiling project to see if there's anything we can do to help, which we are confident there will be.
All Squared Tiling
Tiling Jobs | Find a Tiler - Post Tiling Work Here
Tags Tags
tiling
All Squared Rob,
All Squared Rob,
