Angle Grinder or wet cutter
I use both and wonder how i managed before without my angle grinder. A good wheel is a must and dont try and force it through the tile. It also helps if you get one of the smaller diameter body grinders such as the bosch blue range. That helps you grip the grinder better.
Most tools have hazards, i know a guy who broke the tip of his finger when he crushed it in a rubi snapper.
I have a small grinder but its only there if its not worth the hassle of setting up the wet cutter.
Used to be an industrial roofer and I'll never forget my boss using a big grinder to cut some metal cladding,he slipped and went straight through his thigh,me and my mate had to get the forklift driver to put a pallet on his forks,boom it up and get him off the 40 foot roof onto the pallet as he couldn't get down the ladder.
He was alright but he still doesn't take enough care when using it,lets hope it doesn't happen again.
Angle grinder, pro:
Good mobility
Good for cutting difficult shapes (though I prefer a combo of hand scoring tools, drills, and nippers)
Angle grinder, con:
Lots of noise
Lots of dust
Unsafe
The edges tend to get chipped
Can easily damage/crack tiles
Wet saw, pro:
Fast once set up
Good at straigt cuts
Good at mitering/jolly cuts
Some can do reversed plunge cuts
Fairly clean edge
Wet saw, con:
Low mobility
Can get messy
Needs refilling of water
Needs cleaning at the end of the day, or more frequently if used alot
Both have their uses.
I always try and use an agle grinder over the wet saw anyday. It is a must for new tilers to learn how to use this underated tool properly, knowing how will increase your productivity 3 fold there by increasing job turnover times and profits. Try and buy a thin barrel type as these are designed with the tiler in mind I use Metabo which are light and powerful last a long time even in extreme cutting situations. The grinder is no more dangerous to use and master than any other powertool. they are inexpensive and give you freedom especially if working in multi level dwellings, No up and down stairs to the wet saw.
I will give some sound advice in Mick's speedy tiler tips next week on using the angle grinder, wheel selection, cutting techniques, Safety and maintenance so all new to tiling can learn to master the art of using the angle grinder to improve your speed and your profits.
Angle grinder being dusty, my wet cut has more dust on it these days as it sits in the van most of the time..:lol:
used angle grinder for first time on slate last week (only because it fitted in bag on train) very dusty process lots of kickback like guys have said, but it is portable and good for shapes. i thought also it might be useful for shaving a window reveal if it wasn't quite right but then again i did get chipping of the tile edge which wasn't too good! possibly be used as an emergency but will stick to wet cutter as i feel an accident would be around the corner.
just to follow on about kick backs from angle grinders.
bosch do a 115mm angle grinder which has a safety feature built in which stops the blade and helpd eliminate that problem. i have a big makita petrol saw and it cuts out when it jams and bosch have put the same safety feature on the new models...just worth a thought if you are just about to go out and buy one.
I agree that new new tilers should take time to learn how to use an angle grinder properly, and I do agree that it's a very versatile tool which is very good to bring on smaller jobs, but seriously, at individual tasks, it's average at best. It's good enough as a beginner's tool, but when you're established, you should invest in some more proper tools, for many reasons.
First off, increasing productivity three times is definatly an exageration. A good wet saw does a better and faster job at almost everything you can do with both an angle grinder and wet cutter, once it's set up. For curved cuts, there are far better and more efficient options than an angle grinder, and the same goes for cutting holes.
Second, there are health issues to consider when using an angle grinder: It's very noisy, and very dusty, even if you use a dust catcher.
I hate coughing orange/brownish after a long session with the angle grinder, and I use a bloody dust mask. (Btw, if/when you stop coughing that crap up, it means your lungs are in pretty bad shape.)
Sure, If I've got one or two L-cuts to do on a kitchen splash back, I use my grinder, but I always use protection (which I always carry with me), and besides, given that I keep most of my tools in my car, it's not such a big sacrifice of time to set up my small wet saw.
If I gain some comfort, and preserve some health, by using tools which take me five minutes longer to set up, and five minutes longer to clean and pack up, I'm very happy. Even if you use protection, keeping the dust levels to a minimum lets your lungs last longer, and the same thing goes for your hearing if you can keep noise levels down.
I do not want to put my hard earned money towards sitting in my own filth in a nursing home when I retire early, just because I didn't have the forsight to minimize any abuse on my body.
I've found that using proper, and proper sized tools, increases my job satisfaction quite alot, and that coupled with proper protection and support, I'm probably saving alot of money by staying healthier longer. One sick day means alot of lost income and a distrupted schedule, and when you do get sick, it's more often than not something which takes longer than a single day to get cured from. This is especially true for us in the construction business; There's like two dozen lung diseases which mainly affect us due to all the crap we get subjected to on a daily basis.
Even if all this pansying around, thinking of my health, job satisfaction, comfort levels etc, was decreasing the profit I pull in, it would be worth it to me, because I work for a living; I do not live to work.
I've seen quite a few burn out/get sick in the middle of their prime, just because they weren't careful. Where's the productivity in that?
Just some thoughts...
Missed me mate? 😉 Been up to the armpits in work lately, so I haven't felt particularly inclined to write things on teh interwebz 🙂
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
