Discuss Anhydrate screed prep spec check in the Australia Tiling Forum area at TilersForums.com.
How long did the sanding take you and which machine did you use ?
Alan I have found if there is any moisture in the anhydride that sand paper discs clog and grip the floor causing the rotary machine to overheat, when taking the laitence off of anhydrite floors carborundum stones work far more effectively on a rotary machine and as they have a smaller surface area on damp areas they don't strain the motor or gear box of the machine unnesscesarily
dust is a big issue and we went over to dustless grinding and bagged dust collection I really think saying a 150 m floor can be done in an afternoon with a rotary machine is un realistic but if you have done it then I must be doing something wrong and would appreciate some tips
we have tried several types of machine and spent a fair amount of money tooling up for anhydrite prep work and all floors are different I suppose depending on the product and installers
spoke to Ardex help desk........... we de scabbed it with a brute, primed it well, and fixed ditra after 3 days......
I can say without a shadow of a doubt that if you have stuck ditra down after three days of the screed being installed using an Ardex system there is absolutely no way on earth that it would still be stuck down after 3months...
not surprised. Would still be wet.I tiled an anhydrite screed after 7 days, builder was desperate to get clients in & that floored lasted 2 or 3 months.
Think the floor had given up after a couple of weeks but wasn't ripped up till then.
When I say ripped up what I mean is the tiles were picked up from where they were laid.
Out of interest Stef, what adhesive did you use on this floor that failed?
I'm certain that it was Weber rapid SPF with one coat of PR360.
We had stuck two off cuts down, one primed the other no primer & they both peeled off the floor in a couple of days.
We gave the floor a quick once over with a bit of sandpaper.
Everyone knew it was going to fail but they just wanted the floor down to get the client in then deal with it at a later date.
What made me ask is, BAL make green screed, that can apparently be used within hours of a cement based screed being laid (personally never used it), I wonder what would happen if the likes of anhyfix was used on a calcium screed after a few days? I assume tilemaster have tested their product rigorously, I wonder if a wet screed was in the testing???
Reply to Anhydrate screed prep spec check in the Australia Tiling Forum area at TilersForums.com
