Discuss Anhydrite Screeds: Are You Confident When Tiling To Them? in the Canada Tile Advice area at TilersForums.com.
I am doing one as we speak. I am 100% confident on how to deal with them having done approx, 250 m2 now. Follow the correct procedures and you will be fine; remove laitence, then moisture test after this has been done, commission UFH, then moisture test again, use a suitable gypsum based adhesive to either stick tiles or any membranes and always tank any areas that are likely to get wet.
Are gypsum screeds/adhesive used in wet area bri?...
In the first house I did all the bathrooms were wet rooms and all of them had calcium floors, all waterproofed with dural ci++ and corners/joints taped, lapped 100mm up the walls as well.
I think we all have doubts now and again dave..
I like your method of using the black pads.. how long them they last mtrge wise.?
Question..
How do you know what the screed is?
Say the screed has been down a couple of years & no one knows who poured it, how do you test to find out if its concrete or a calcium screed?
Lol, how long has the screed been down?
How high have they got the heat..?
Reply to Anhydrite Screeds: Are You Confident When Tiling To Them? in the Canada Tile Advice area at TilersForums.com
