Discuss Anyone had trouble with these? in the Canada Tile Advice area at TilersForums.com.
Chalker
1,058
Tadcaster
Did a floor a few months back. 1970's house with t&g floorboard. No deflection. Floor only 3square meters.
floor covered with no more ply. And used nicoflex adhesive with superflex grout. ( 3mm joints)
the floor has cracked about the width of the room on where I know there is a joint in the no more ply.
going to take it up and re lay.
has anyone had any trouble or used these in the past?
On the box the only info I have is.monterroy solo cemento. 333mm square.
L
Lee garnham
Personally I always ply. I recomend 18mm even for over boarding I will only use a minimum of 12mm if I cant get away with 18 ie door thresholds etc. What ever you are tiling into needs to be made as solid as you can possibly make it. Try and turn what ever your working on into one big solid lump. Ill check all floor boards are solid gripfill any joint I dont like the look of and glue and screw ply to the deck screwed at approx 150mm centres.
Reply to Anyone had trouble with these? in the Canada Tile Advice area at TilersForums.com
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
Bit of an intro - I'm a competent DIYer and have been refurbing the bathroom on and off for the...
6K
L
Hi All, I’ve just had 2 rooms tiled with oak effect ceramics and I feel a little disappointed...
5K
Hi all Got a shower to do with these tiles. They are 450 x 440 porcelain, split into 4 by a 1mm...
Unused Account 1
U
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
Chalker
Tadcaster
Business Name
Walker plumbing and heating
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
