Discuss Application of SLC in the UK Tiling Forum area at TilersForums.com.
cornish_crofter
Well, I finally got around to sorting out the floor today.
But not before I went shopping. Firstly to Tesco and then Trago Mills (Liskeard)
I was on the look out for some kind of long armed spreader.
These are what I ended up with.
On the left is a £1.50 squeegy bought from Tesco and then taped and screwed to a cheap broom handle I had.
On the right is some sort of floor scrubber/squeegy from Trago Mills costing me £5.25. It actually came from their equestrian department.
The Tesco tool was better at getting into the corners etc, whereas the Trago one was very good at spreading, via the bristle section, then I simply turned it over to give me a smoothing edge.
Again, here is the trago tool in a better shot so you can see the type of item that it is.
cornish_crofter
The squeegies from Tesco are probably the easiest to get. £1.50 in the homeware section.
As for the other item - any equestrian store may have them.
The SLC has been a pain TBH. It's down now and I think I've managed to get it to level within a mm or two. But I didn't want to go any higher than the high spots so I've had to level up to them. This means that the SLC tapers to a thickness of less than 1mm. IIRC it's designed for a minimum depth of around 3mm
Anyway, I don't think it's anything that a bit of rapid set can't sort out. I know it's pretty level on the whole as I can just see all my screws.
Reply to Application of SLC in the UK Tiling Forum area at TilersForums.com
Hi All, after a short time off the tools my first job back and im having a head scratching...
How to drill a hole in a steel bath. At 365Drills we provide either the equipment you need or...
6K
Deleted member 1779
Afternoon all and a Very Happy Xmas! I'ts been a while since my last posts but I have been...
diamondtiling
Expert advice for professional installers on drilling porcelain tiles. By Richard Hazell of 365...
6K
jamesy07
The following is an article written by an eminent stone professional in the USA - please read it...
DHTiling
Application of SLC
