Discuss applying adhesive methods? in the UK Tiling Forum area at TilersForums.com.
Pro-spec
alot of tiles i knock off reveal that they have been fixed to the wall with blobs of adhesive to the back of the tile instead of the adhesive being spread and notches on the wall.
do people use this as an alternative to notching permanent or is it only done when say walls are out etc?
what's the usual method? 4 blobs each corner and 1 in middle?
whats the dis/ advantages of this?
I did blob method on a floor once which was onto under tile heating wires , and then just made sure i squeezed plenty of grout in the joints.
Diamond Pool Finishers
i wonder how many spot fix tile jobs there are in the uk ?and what percentage of new tile/stone installations are spot fix still today, and what the success rate of them would be .......i have pulled lots of spot fix Bathrooms,floors,kitchens to pieces that are only being changed because of updating,and have served there purpose well, i'am not condoning the spot fix method ,but BS standards are only recommendations ,i think they should be Law now ! well european standards
Muse2k8
What I usually do after putting in blobs and sticking in place (just start with full tile in corner it's so easy) is use a lump hammer to even them out. Usually if I'm using stone I don't bother to seal them... Takes too much effort.
Did this great job last week. White marble and red grout. Just used an icing bag to put the grout in then wet a cloth and gave it a wipe to clean. Easy.
Didn't bother with Silicon either. Just butted up the corners at the wall etc. nice solid mdf wall and a good 6mm chipboard floor.
Alan M
:lol::lol::thumbsup:
White Room
Quality:lol::lol:
charlie1
Yeah, I wonder that too as I know a few fixers who spot fix, I know they do a lot of travertine and heavy porcs so, with the combination of poor fixing and natural stone becoming more popular, are we sitting on a time bomb? We all know the weight restrictions for different walls but I've allways wanted to do my own experiment using weights to see just how much weight a wall will take!
Drastik Lee
:lol::lol:
White Room
You would probably find they would exeed the weights but the bs weights are a safe level, if they gave the figure slightly higher for tiles then they would exceed that which make it a dangerous issue...
Martino
Personallly i blob fix and also spead adhesive every job is different!...1 rule i always go by is..NEVER BLOB A FLOOR TILE!....it will crack no doubt..if someone stands on a hollow part then crak goes the tile!! NOT GOOD!.....with regards to people with underfloor heatins..simply spread the tile and not the floor it does the same job!...can be a tad messy but its the right way!
widler
1,328
England
Muse2k8 is that you again,have you made another user name,come on,own up,its you aint it:drool5:
Reply to applying adhesive methods? in the UK Tiling Forum area at TilersForums.com
Hi all, Have a question about how/when best to install tile trim - probably quite basic! One...
Can I ask advice please; I have MS and the worry is making me ill. The tiles are all chipped...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
