jordelver
Hi,
I'm a newbie DIYer and probably in way over my head. There is no turning back. There may be tears
I am going to be installing an Aqua Dec in my bathroom. The whole of the floor including (obviously) the Aqua Dec are going to be tiled. Large tiles for most of the floor with smaller (textured) mosaics for the shower area.
The bathroom is currently all timber floorboards - 22mm thick. The Aqua Dec is also 22mm thick, however I'm also going to be installing underfloor heating (Devimat) and I was going to lay an insulation board of some type to a) insulate the floor for the heating, and b) create a nice flat surface to tile onto.
So, by the time I add on the thickness of the insulation board and tiles, either the Aqua Dec is going to have to be made higher, or the rest of the floor lower or else I'm going to be going up a step to get into the bathroom.
Given this, what would be the best course of action? I could remove floorboards, put down ply and an insulation board with the hope I can find those materials in the correct thicknesses. Would that be strong enough?
Thanks for any advice you can give.
Cheers,
Jordan
Cheers,
Jordan
