Aqua Mix Floor Shine and Hardener for Slate
F
Frontier_Steel
Hello everyone
I just had a quick question regarding Aqua Mix Floor Shine and Hardener. I just applied two coats of enrich n seal and was wondering if the hardener should be applied before or after grouting... To my understanding it could be applied either way but what is preferred?
Thank you for any and all replies
Matt
Hello Matt and welcome.. you need to seal first mate.. then use the maintenance liquid after.
Hello Dave, thanks for the welcome...
I thought the Enrich N Seal covered the sealing part-
DESCRIPTION:
AQUA MIX ENRICH’N’SEALTM is a premium, no-sheen, enhanced-look 100% Polymer-solid, penetrating sealer formulated to darken, enrich, and highlight the character and beauty of unsealed natural stone with Polycure TechnologyTM. It rejuvenates the color and improves the appearance of worn and weathered stone. May also be used as a pre-grouting sealer.
The enrich and seal is the sealer.. it does darken the stone etc.. then the floor shine is like a topical coat.. this is used afterwards or the true properties of the sealer will not work..
Ok I got that but should the topical coat be apllied before or after grouting? Or does it even matter?
Frontier_Steel,
DHTiling,
Frontier_Steel,
DHTiling,
