Discuss Aquapanel and Eggbox Walls in the UK Tiling Forum area at TilersForums.com.
Following recommendations on these forums I have gone for Aquapanel to line the walls around a bath that will have a shower over it. The intention was to replace the plasterboard with Aquapanel where necessary and add in extra noggins at the same time if necessary.
However having removed the old suite I now discover that the plasteboard wall is in fact a single piece panel with two sheets of plasterboard seperated by an eggbox type construction (much like a cheap interior door). So obviously removing one sheet of plasterboard is not an option and there is no studwork to screw into.
The only thing that I can think of doing is to screw directly into the plasterboard but put some Gripfix type adhesive on the back of the panel first to give added mechanical strength to the bond. I can't build a studwork frame in front of this wall because there is only just enough room for the bath as it is.
Would this be a satisfactory solution?
Andrew
structural is the question as the wall may still not be suitable to be tiled what type and size tiles do you have in mind
Tiles are 400mm x 250mm ceramics. If the wall does not have the structural strength then I am wondering why the plumber mounted a boiler on it when the central heating was installed.
without seeing it i would say do some research on this type of wall .others will be along shortly they may of worked with this type of wall .not keen
Well, it would appear to be calle 'Paramount Board' and judging by what I have found so far it would appear to have the same weight handling characteristics as plasterboard when it comes to tiling. So that is good. But I need a waterproof backer and while I will get some holding ability with a grid of screws into the plasterboard (there are apparently small studs on 900mm centres) I was wondering whether a belt and braces approach and using Gripfill or similar would be a good idea.
Can you not leave the board in-situ and use a tanking kit or membrane instead of the aqua panel..
No technical reason but I already have the Aquapanel as a result of advice on these forums that it was a better solution than tanking. This, of course, was before I knew that it was not going to go on a normal stud wall.
OK, you've convinced me. Tanking it is. I reckon it is about 4sq m. The wall behind the shower will be Aquapanel since it has proper studwork. Some people talk about tanking, other mention a membrane. Would something like Screwfix item number 78484 do or do I need some sort of full membrane system?
Reply to Aquapanel and Eggbox Walls in the UK Tiling Forum area at TilersForums.com
A
Hi guys, Newbie mistake combined with some duff advice:mad2: I've put 6mm hardiebacker around...
16K
Hi all, First post, so please be gentle! Preping our bathroom to drag it out of the early 90s...
22K
I need to tile 3 sides around a bath with a shower going into it. Two of them have been stripped...
20K
P
Hi, I'm a DIYer in the process of fitting a walk in shower into my bathroom. I've not attempted...
11K
11K
Rizzle from the Portizzle
R
Cambridge
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
