DS Tiling
I am looking to strengthen an 18mm chipboard substrate to take 333x333mm travertine. I would normally use 12mm aquapanel spf'd and screwed for such a job but was thinking of trying the 6mm Hardibacker to reduce the height a bit. I am slightly nervous of the thin hardibacker and don't want a failure as travertine requires good preperation. Has anyone used the 6mm hardibacker spf'd and glued and how rigid was it or should i just stick with the Aquapanel.
