Discuss Aquapanel or Hardibacker in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
Hi all,
6mm Hardiebacker is fine to use on the floor and is used in millions of homes in America (can you guess its the rep speaking.)
We would recommend a fast flex adhesive to put under the board and a fast flax on top as well.
Just to clarify, do you mean a flexy rapid set adhesive?
Grumpy
N
Northern Bird
Sorry I am not 100% on actual name the notes I have from BAl is when they checked for their own records to make sure it all worked ok they recommend fast flex adhesive on the 6mm and the 12mm you can use a flexible, single part or a cement based with additives.
For Dunlop this is a 2 part rapid flexible.
Are these the adhesive brands you use?
If not I can try to speak to the other companies.
We have produced the 12mm Hardiebacker for use on the walls as this can fit in with 12mm plasterboard as we know most tilers will not do the whole bathroom in backer.
The 6mm has a 3mm notched bed of adhesive underneath and again ontop.
DS Tiling
I had presumed as the 6mm boards were being advertised for floor use that they would be denser and more rigid than the 12mm boards. From the above that doesn't appear to be the case. Aquapanel provides a flexural strength figure for their board. It would be helpful to have these figures for all boards so a like for like comparison could be achieved of how rigid the boards are in comparison to each oher.
N
Northern Bird
DS, I havent got that on my laptop but I will ask our technical guy and find out and post back. He doesnt work weekends do I am afraid it will be monday.
Does anyone elase have any questions I can help with?
grumpygrouter
6mm boards are, in fact, more dense than 12mm, it says so in their literature. However, I don't think it is as rigid as the 12mm.
Grumpy
Reply to Aquapanel or Hardibacker in the British & UK Tiling Forum area at TilersForums.com
5K
Hi, new member here! I'm about to tile the walls and floor of our shower room. The floor at the...
Hi All First post long storey short had arranged for someone to re model my bathroom on the...
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
