K
k13wjd
Hi guys, first post here, so go easy. Im doing a full rebuild of my bathroom ( at the same time as installing a central heating system)
The old tiles got removed, as they were a tad "wonky" and old fashioned. Under the tiles i found nasty 50 year old plasterboard, with holes and all sorts. Problem is its paramount - so no studs to screw to.
New 9.5mm boards have been put up, secured by various methods - Expanding foam, Gripfill, Dab+Dot......
My problem is that the biggest wall, ( 2.4m tall, 2.2m wide.) isnt flat.
The centre of the wall is around 10mm futher out from the edges....its fairly gradual, and isnt linear up the wall. I.e its around 3mm at the bottom, 6mm at the top, but 10mm in the centre.
How much of a problem does this cause for a tiler ( i'll be employing one, My tiling is as bad as my plastering !)
Thanks in advance.
Thanks in advance.
