Discuss Are they flat enough.... in the UK Tiling Forum area at TilersForums.com.
the only thing with putting a skim coat on the boards is the weight issues the large format tiles will probably exceed the 20kg limit for skimmed walls.The expanding foam is pretty strong stuff and I'm sure it will do the job, for future ref if you stick a dozen screws with washers in each board it stops it expanding unevenly.
If you go for smaller tiles and lay them in a traditional square manner, either portrait or landscape they should adopt the contours of the substrate and you may get away with it. If you decide to go brickbond that will become harder as the corners tend to poke out.
The larger the tiles get then the harder the job becomes as they don't 'bend' with the wall as the smaller ones do. The worst case scenario is large format rectangles set brickbond as you'll have to use your highest point as the level for the whole wall - in your case having up to 10mm behind some of the tiles which is beyond the bed recommended by most adhesives and makes the job a lot more fiddly for your tiler. If you want this option I would suggest putting a skim coat of plaster on first to make it level, wait a month for that to cure and then crack on.
Bear in mind the idea is to get over 90% coverage of adhesive on the back of the fixed tiles, that's more likely with a flatter wall.
Reply to Are they flat enough.... in the UK Tiling Forum area at TilersForums.com
