Discuss Back Skimming in the Tile Adhesive and Grout Advice area at TilersForums.com.
Dave
Staff member
Subscribed
389,930
1,000,000
Co.Durham
When back skimming 650 x 450 porcelain floor tiles used with levelling clips, do I use the notched side or smooth side of the trowel? If the smooth part how thick does it need to be?
Flat edge is fine. As above a couple mm.
Sean Kelly
1,068
Ruislip
You want to cover the back of the tile with the smooth side of your trowel. The adhesive will seal in any dust you may have on the tile. It will also cover all the indents on the back of the tile and it will give you an extra 1mm (or more) adhesive to form a good bond with the adhesive on the floor.
Reply to Back Skimming in the Tile Adhesive and Grout Advice area at TilersForums.com
    • Optimistic
My tiles are moving after 3 days of been layed on Cement floor. I used MapeGrip D2. just seen a...
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Hi guys, had some great advice here before so thought I would ask here for advice again...
Tile Adhesive Trending Topics
Cheshire
What member type are you?
  1. Professional Wall and Floor Tiler
  2. Bathroom Fitter
Back Skimming
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
