Discuss Bad luck...skint....and thinking of quitting in the UK Tiling Forum area at TilersForums.com.
CJ CERAMICS
Sorry guys and gals
this is not a very cheerful thread but after the week that i have had i dont feel very cheerful.
bad luck started on monday when my fein packed up (bought it 6 months ago) and the company i bought it from are stating that fein should fix it and fein are saying that the retailer is responsible.
On way home from work my van broke down and would not restart.
phoned a friend who owns a garage who kindly towed me to his garage and said that he would look at in the morning.
On wednesday he phoned to say that the computer system installed in the car was dead basically and would need replacing, but sadly he would have to send it to a specialist.....after a couple of phone calls back and forth this is what i have been quoted......
£575.00 +vat for computer
£75.00 + vat to set up computer before installation.
£75.00 +vat to fit sald comp per hour possibly 2 1/2 hours?
total of £1005.00 to fix, but due to the fact that they are in warrington somewhere they had to put the van on a low loader and transport it there
cost £125.00
i also needed a new fuel pump as well as this is now not working due to above problem. £150.00 plus vat and fitting total cost of £225.00
so all in all a Astra van which i bought for £2k has cost me £1355.00 to fix.
Got up this morning to go to work and guess what it broke down at the end of our road.:incazzato::incazzato::incazzato:
So i went home and borrowed the wifes car, now this is were i get really annoyed, nipped into B & Q as i needed a new blade for my jigsaw and it was on the way.........came out and drove to job.......after an hour or sowent for a smoke break with the plumber who is there and he went to get something from his van....and asked "when did you do that to your car" at which i jumped up to find that someone or something had driven down the side of my wifes car denting and scratching the back panel and rear passenger door and had then driven off, :incazzato::incazzato::incazzato:
so basically I am now skint, with a van which still does not work and i will have to find out how much it will cost for the wifes car.
Oh and to make things worse(in my head anyway) i only went to work because i got up early to watch the rugby and thought i can get ahead on the job lol
chris
Colour Republic
Astra vans are known to have faults with the ECU, my mates van had it.
I don't wish to rub salt in the wound but sometimes the ECU can be reset. Or you can get replacement non-genuine parts off ebay for a lot less. What is often the problem is the ECU messes up and injects the wrong amount of fuel. Which might have been why they said the pump had gone too – misdiagnosis? It could have been completely knackered but I know my mate fixed his for about £250 and most of that was 1) somebody with the software to diagnose and 2) somebody calibrating the new ECU to his van. Although to be fair he spent a long time reading up on astra forums and contacting various people.
On your wifes car I would get on to B&Q straight away and get copies of their security cameras and hopefully someones been caught on it.
Sorry to hear your bad luck. I know it won't help but 'Chin up' ;)
E
enduro
Had the same fault on my wife's Toyota RAV4...my mechanic could get the ECU for £80.00 but could not get the codes from the dead ones from the Toyota. Only Toyota had the software to do this and they wanted £2,000 to fix it :incazzato:I phoned everybody i could find to see if the could remove the codes from the ECU and they all said Toyota were the only ones who could do it. So i scrapped the vehicle in the end.
U
user123
Chris, life like energy, travels in waves, you're obviously in a down one. Things will go up again, it's the nature of things. Look at things calmly and realistically as you would for your best friend, see how big these issues really are, take a deep breath and step by step work yourself out of this hole. Going further into it won't help. Remember the 'keep calm and carry one' ... all will be an interesting story by next year... :)
CJ CERAMICS
Went into B &Q and spoke to the manager, it seems that the cctv cameras only operate on the first 2 lines of parking spaces and they dont have them over the rest of the car park, sadly i was parked further away than the cameras covered, also tbh it could also have happened at the job site as we have to park on the road/pavement as the customer wont allow us onto drive(newly laid block) and the road is a bit on the tight side.
macten
1,158
Nottingham
Feel for you bud!
With regards to the Fein - under sales of goods act it is the retailers responsibility to refund/replace
so get back on to them and quote that and they will sort it out - many companies rely on consumers
not knowing their rights.
The Sale of Goods Act makes reference to ‘the seller’, this is the shop, the retailer, or the individual you bought it from, and is who you made the contract with. It is not the manufacturer, and don’t let the shop tell you otherwise! If there is an obvious fault with the item at any time within the first 6 months and it has not been caused by wear and tear or misuse, your first port of call must be the shop you bought it from. They have the responsibility to put the matter right, and should not evade this responsibility by referring you to the manufacturer in the context of a guarantee or warranty. Even after this 6 month period, if the item breaks down prematurely , you should always go back to the shop or retailer in the first instance.
Your statutory rights under the Sale of Goods Act take precedence over and above any warranty or guarantee you may have with either the retailer or manufacturer. It is misleading for a shop to tell you they can do nothing simply because their warranty or guarantee has run out, because you will still have your statutory rights.
With regards to your van I would recommend www.breakeryard.com.
Just got a power steering pump for my van for £35 delivered next day - better than £300 for a new one (bearing in mind
the one that packed up was only 16months old!)
Reply to Bad luck...skint....and thinking of quitting in the UK Tiling Forum area at TilersForums.com
We had our loft bathroom done a month ago and are having issues with the tiler (recommended on a...
Vinny Kehoe
V
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
I was quoted over £4700 (inclusive of VAT) to rip out and replace my bathroom. This does not...
7K
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
