Discuss BAL White Star or Mapei Keraflex in the UK Tiling Forum area at TilersForums.com.
siremastimus
About to start tiling bathroom walls with 25 x 38cm ceramic tiles and being a DIYer was after something with a longer pot life. The White Star seems to be quite highly spoken of on here for a tub mix and people also say Mapei is good - which would people say is the better option the white star or the keraflex? Thanks
Gazzer
I would opt for keraflex out of those 2 choices.
495
1,118
Somerset
welcome sire - I have used white star in same situation in the past and it was fine. Most professional tilers want to use a cement based adhesive on walls because it gives better grip, is cheaper (per square meter), can set much more rapidly ( we dont always want a long "pot life") and is really a better adhesive in the long term (less likely to go "soft" when wet).
You may find it easier to use white star as DIy-er - you can use it straight oput of the tub and cement based adhesives are much easier to mix using an electirc mixer (more expense for a novice).
Have fun!
AliGage
Subscribed
4,531
1,188
Peterborough, England
Your tile is over the recommended max size for white star.
I don't know much about other brands i like BAL and always use them. A bag of BAL single part flexible will be cheaper than white star, easy to mix up and as a DIYer the 5 hour pot life should be ample time to complete an average wall.
I'm sure other brands of powedered adhesive on here are just as good as the BAL equivalent. I wouldn't use a tubbed adhesive.
Reply to BAL White Star or Mapei Keraflex in the UK Tiling Forum area at TilersForums.com
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Thank you for looking. I am about to tile the floors and walls of a small bathroom. I am using...
  • Question
The wife wants to renew kitchen wall and floor tiles and we have been looking for a few weeks...
So... have a problem maybe some of you guys (and girls) might be able to help with. Laid a new...
19K
So after a couple of weeks trialing @ISOMAT UK products, thought it was time to give initial...
9K
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
