Discuss Bal white star used in error on floor! in the UK Tiling Forum area at TilersForums.com.
ceesjm1
I have just discovered I have used Bal white star on the floor by mistake! The floor consists of 18mm WBP plywood secured every 200mm between centres on top of floor boards. The plywood was also primed with bal sbr. The tiles are 151 x 151mm Victorian tiles.
Have just about finished the floor tiling and was not due to grout till end of the week. The big question is can I get away with the white star or will it all need to come up. I'd rather lift them now than do it with all the bathroom furniture installed........can't believe I got myself in this situation!!!!
Any help greatly appreciated
macten
1,158
Nottingham
It's not really worth the risk hoping you'll get away with it. Shouldn't be too hard to lift tiles now without causing damage and relay using correct gear.
Did you prime the reverse and edges of the ply or the face?
Ajax123
1,213
Lincolnshire
They should be ok to remove but my query is how can you mistakenly use an adhesive for a whole floor.....surely you knew after the first bucket was opened?? Or do you mean yo did not know it was not the right gear??
DHTiling
By mistake.. oh ffs where oh where!!!! do you guys come from ...
Reply to Bal white star used in error on floor! in the UK Tiling Forum area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
I recently got several loose/hollow tiles rebonded on my bathroom floor. Having left with...
need eyes in the back of your head. Using Norcros NX standard set floor tile adhesive. After an...
    Votes: 8 5.8%
    Votes: 13 9.4%
    Votes: 9 6.5%
    Votes: 40 29.0%
    Votes: 16 11.6%
    Votes: 34 24.6%
    Votes: 3 2.2%
    Votes: 20 14.5%
    Votes: 18 13.0%
    Votes: 15 10.9%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
