Discuss Bath panel - corner finishing?! in the UK Tiling Forum area at TilersForums.com.
jimshatner
Hello Tilers all,
I'd be much obliged if some kind soul could advise me the neatest way to finish the corner of a tiled bath panel. The tiles are beautifully flush to the bath, however this means that even with edging trim the external corner protrudes beyond the curved corner of the bath edge. I've spoken to two tilers who told me there was nothing other than putting something in the top of the trim, but with the wealth of experience I wondered if anyone had any other ideas.
Thanks in advance
Jim
MICK the Tiler
Not much that can be done, if the bath panel has not been set back far enough to allow for the curved corner. A while ago I fixed a similar problem by using 2 quarter round trims placed back to back then I ground the spine off with my grinder so as to make a half round nosing to match the round corner of the bath, I then superglue the trim together and laid the tiles. It solved the problem, but it was alot of messing about.:mad2:
jimshatner
I ALWAYS RECOMMEND HAVING ABOUT A 100MM SHELF ON TOP OF THE PANEL.TILED TRIMMED AND A TRIM CORNER PIECE TO FINISH THE INTERSECTION:grin:
Thanks for your reply. Just to clarify, do you mean that the tiles/panel will protrude from the bath edge by 100mm all the way round, which you you would tile on top of, and presumably this shelf will be raised to be flush with the top of the bath?
Jim
andersontiling
Jim
i set it so the tiles on the shelf tuck under the lip on the bath
andersontiling
Reply to Bath panel - corner finishing?! in the UK Tiling Forum area at TilersForums.com
We recently finished a bathroom renovation where the two builders who did the bathroom also did...
any help on this would be really appreciated because i have been allover the place trying to...
Wondering what the options (and fashions) are for edging. Particularly outside corner edges...
We have had a tile tile a bathroom and an ensuite and are not happy with the overall finish of...
6K
Hi All I'm looking for some advice from the experts and hope you can help. I've just had a...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
