Bath tile trims....advice needed
if i get you right philip the external upright trim could be a square one (rather than round) which would match nicely with the two horizontal trims (at the 3 way mitre) hope this is of use...rik
nice job by the way..
genius..... never thought of that!
Thanks, i'll go and have a look tonight.
Thanks for the compliment, i'm quite chuffed for my first attempt, i'll post some more pic's when it's finished
yes philip square trim would work or you could mitre the vertical plane its not that hard and only a few tiles looking at the pics you look more than capable mate
Might be a daft question but why didn't you build the bath frame a bit narrower to accommodate your panel and tiles?
Grumpy
i always cut a slot in the board so the metal frame sits flush with the front of the board so when you tile it the tiles sit under the lip of the bath save water sitting there always think it looks a bit neater as well but it depends how much it protrudes also i always cut a panel out 20mm smaller than a tile/s as a access panel and Silicon the joint
Grumpy most people put the panel against the bath frame instead of flush which makes it difficult to get the tiles under the bath lip
Ok, not tiled a bath panel yet so I am not familier with the problems that can arise.
Grumps
