Happened to me once so far went really patchy on the last job on a porcelain tile but has dried perfect on this job these are ceramic but I’ve been using ultra tile silver grey which is the same colour as gunmetal and had no problems what so ever with itThe last 2 bathrooms I used gunmetal MM2 on went ever so slightly patchy, not that noticeable but have never experienced it before.
I rarely use topps or Ctd I normally shop at the smaller independent tile shops around meYou should at CTD and you get 200 Weber reward points per 5kg bag![]()
CTD is my go to placeI rarely use topps or Ctd I normally shop at the smaller independent tile shops around me
I’ve had same problems with Mapei, sanding sorted itIts really odd, I know some have had problems but I have never experienced it before.
Going to change, thought about trying Keracoll Fugabella but need to get to Pro tiler to see if I can get a colour chart and set up an account.
Had problems with the smoke and the gunmetal and haven’t tried the Keracoll grout yet but if it’s anything like the adhesive they make I’m sure it will be goodIts really odd, I know some have had problems but I have never experienced it before.
@antonio our resident Italian pro tiler doesn’t rate the Kerakoll cement based grout very highlyHad problems with the smoke and the gunmetal and haven’t tried the Keracoll grout yet but if it’s anything like the adhesive they make I’m sure it will be good
I’ll give it at go at some point as it’s always good to try different products@antonio our resident Italian pro tiler doesn’t rate the Kerakoll cement based grout very highly
pro tiler?......I'm not used to this qualification...@antonio our resident Italian pro tiler doesn’t rate the Kerakoll cement based grout very highly
