Cabnero
Hi again guys. I'm on day 2 if tiling my mum's bathroom thanks to you all with help prep and layout which I'm happy with. However there is a couple of problems which I should have checked and asked about. Firstly the walls have been dot and dabed by the builder and screwed and plugged. However I've only today noticed slight movement in the wall where it meets the window wall. I know I should have double checked but it is half tiled now. There is a dab unscrewed which I will plug and screw but don't think it's going to make a difference. Can in do anything else. I.e use a long screw. Any suggestions would be welcome. Can I check re the hardie. It's down and screwed with turbo golds 4 x25 as suggested. Some of the heads are slightly proud of the board. Is this OK or will I be ok to screw them again. Thanks again fellas.
Yeah roughly. I think there is a missing dab horizontally between the one I've mentioned and the area of movement. Trouble is not sure about the quality of the builders work so can't day he'd have done this "by the book". I can call him tomorrow to find out.
