Discuss Bathroom wall tile repair, unable to match tile size. in the Bathroom Tiling Advice area at TilersForums.com.
G
Graham171
In 2014 I had my bathroom re-titled. I'm having my shower replaced and some of the tiles need to be replaced. The tiles on the wall are white gloss tiles 248mm x 328mm (purchased from ToppsTiles). The only size I can locate is 250mm x 330mm. Does anyone have any suggestions of how I can get around this problem without having to re-tile the entire bathroom.
Dave
Subscribed
389,936
1,000,000
Co.Durham
You could try a wet cutter but you might get minimal chipping, how many is there to trim. ?
G
Graham171
You could get them water jet cut. Worth pricing first.
Thanks for suggestion, but you would loose the bevelled edge of the tile, I'm going for small mosaics
[automerge]1602064041[/automerge]
Why so many to change a shower?
That’s 3.3sq m!
Is the plumber heavy handed?
Usually if changing a valve it’s only a couple of tiles, often this can look good by making a contrasting ‘patch’ as you suggest maybe with mosaics.
The shower is actually a wet room and it looks as if there could be soem water leakage behind the tiles.
Reply to Bathroom wall tile repair, unable to match tile size. in the Bathroom Tiling Advice area at TilersForums.com
Hi, i'm undertaking all of the tiling in our project. I have two different types of 600mm tiles...
Hi there, after a little help. Just installed a picture wall with tiles in my bathroom but...
Hi all I'm new to tiling and am looking to start learning from working on my own projects. Am...
Unsolved
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 2 1.2%
    Votes: 5 3.1%
