Guest viewing is limited
best adhesive for travertine
E
evertonl36
would like to no peoples opinions on the best adhesive to use for travertine tiles
keraflex or toppfix flexi(white obviously)
go you mean keraflex MAXI?
there seems to be a common mistake on this site that mentions keraflex!
this adhesive has been around since the start of mapei, 10 years,
there common product is keraflex maxi (S1), keraflex (c2te) is still avalible, but not reccommend for ply etc.!
I'd use white addy with travertine, but surely the substrate will affect what is the best addy to use for a job?? Can you be more specific please?
doesn't say if it is concrete or ply though!
does not matter!
people should no longer use "keraflex" unless its ceramic tiles/porcelain tiles on plaster/plasterboard.
maxi should be used for large format (above 20x25cm!!!!!!!)
and with ply etc.
evertonl36,
doug boardley,
evertonl36,
doug boardley,
