Guest viewing is limited
Tiling Tool Suppliers
Discuss best cutter for traventine tiles in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
Accura Brian
hi There if youur using a grinder which is perfectly fine, make sure its an electroplated Blade with a continuous rim finnish this will reduce chipping. The raeson for electroplated is the diamond is exposed as opposed to diamond held within the metal bond commonly used for cuttting porcelain and ceramic. Metal bonded blades tend to glaze over and become smooth when cutting large quantities of travertine, marble and other very soft natural stone tiles. Never use an electroplated blade on porcelain, the blade will cut fine but will wear out very quick. Hope this helps. When dry cutting usinga grinder always use a dust mask!!!
:thumbsup:
Reply to best cutter for traventine tiles in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Currently using TX700N but obviously now too small for the 1200x600mm I'm increasingly being...
This is the Number 1 Best Tile Adhesive from 2007 to 2021 recorded (almost) annually Discussion...
  • Sticky
  • Poll
Which Tile Adhesive and grout brand did you use the most in the last 12 months? And also...
Popular Tile Cutter Threads
    Votes: 5 5.7%
    Votes: 6 6.9%
    Votes: 5 5.7%
    Votes: 22 25.3%
    Votes: 13 14.9%
    Votes: 27 31.0%
    Votes: 3 3.4%
    Votes: 2 2.3%
    Votes: 18 20.7%
    Votes: 14 16.1%
    Votes: 6 6.9%
    Votes: 5 5.7%
    Votes: 3 3.4%
