Discuss Best Moisture Board & Mapeii adhesive in the America Tile Forum / Advice Board area at TilersForums.com.
I am just about to have a bathroom renovation done and have been reading about different plasterboards. My first question is what board would be suitable for larger tiles 120 x 60 and should it just be cement board or although more expensive, marine ply? Or do you have a better suggestion? The walls are going back to brick and being coated in liquid plastic before boards are put up.
My second question is, using mapeii products which adhesive for the size tile would you guys recommend?
Hi. Why are the walls being coated with this liquid plastic? , can you be more specific
Rather than PVA, liquid plastic is virtually impenetrable, so as we have access to it, seemed like a good idea. the main query is regards to the tile size, boarding and adhesive
Dave
Staff member
Subscribed
389,930
1,000,000
Co.Durham
That’s why i asked, so we can advise on adhesive that will bond to it.
Dave
Staff member
Subscribed
389,930
1,000,000
Co.Durham
Ahh, I get it, this would go directly on the brick and then a board to be affixed as usual, not sure what board but one that would be able to take the weight
Any poly core cement faced board will accept a lot of weight. Check with manufacturers on fixing methods. Most are screw and washer fixing or dowels
Reply to Best Moisture Board & Mapeii adhesive in the America Tile Forum / Advice Board area at TilersForums.com
    • Friendly
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
USA Tile Forum Popular
America Tile Advice Trending
Northampton, UK
What member type are you?
  1. Homeowner
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
